Ir para o conteúdo principal
Dremel 4000 Shaft Lock Pin Replacement
O que você precisa
    1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: passo 1, imagem 1 %32 Dremel 4000 Shaft Lock Pin Replacement, Back Case: passo 1, imagem 2 %32
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      Pergunte ao FixBot
      Comentar
    2. Dremel 4000 Shaft Lock Pin Replacement: passo 2, imagem 1 %32
      • Using your hands, carefully remove hanger from casing.
      Pergunte ao FixBot
      Comentar
    3. Dremel 4000 Shaft Lock Pin Replacement: passo 3, imagem 1 %32 Dremel 4000 Shaft Lock Pin Replacement: passo 3, imagem 2 %32
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      Pergunte ao FixBot
      Comentar
    4. Dremel 4000 Shaft Lock Pin Replacement: passo 4, imagem 1 %32
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      Pergunte ao FixBot
      Comentar
    5. Dremel 4000 Shaft Lock Pin Replacement: passo 5, imagem 1 %32
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      Pergunte ao FixBot
      Comentar
    6. Dremel 4000 Shaft Lock Pin Replacement: passo 6, imagem 1 %32
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      Pergunte ao FixBot
      Comentar
    1. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: passo 7, imagem 1 %32
      • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
      • Remove the damaged shaft lock pin and spring by hand.
      • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
John Cobb
Membro desde: 01/20/16
1.842 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 15-4, Remmell Spring 2016 Membro de USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Membros
Autoria de 17 guias
3Comentários do guia
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Responder Compartilhar
three years later and I came to the same conclusion: DUH
Randy Martin - Responder Compartilhar
Four years later and I came to the same conclusion: DUH
Ben simon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 118
Ao todo: 16,279
