Ir para o conteúdo principal
Dremel 4000 Power Cord Replacement
O que você precisa
    1. Dremel 4000 Power Cord Replacement, Back Case: passo 1, imagem 1 %32 Dremel 4000 Power Cord Replacement, Back Case: passo 1, imagem 2 %32
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      Pergunte ao FixBot
      Comentar
    2. Dremel 4000 Power Cord Replacement: passo 2, imagem 1 %32
      • Using your hands, carefully remove hanger from casing.
      Pergunte ao FixBot
      Comentar
    3. Dremel 4000 Power Cord Replacement: passo 3, imagem 1 %32 Dremel 4000 Power Cord Replacement: passo 3, imagem 2 %32
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      Pergunte ao FixBot
      Comentar
    4. Dremel 4000 Power Cord Replacement: passo 4, imagem 1 %32
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      Pergunte ao FixBot
      Comentar
    5. Dremel 4000 Power Cord Replacement: passo 5, imagem 1 %32
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      Pergunte ao FixBot
      Comentar
    6. Dremel 4000 Power Cord Replacement: passo 6, imagem 1 %32
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      Pergunte ao FixBot
      Comentar
    1. Dremel 4000 Power Cord Replacement, Power Cord: passo 7, imagem 1 %32 Dremel 4000 Power Cord Replacement, Power Cord: passo 7, imagem 2 %32
      • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
      Pergunte ao FixBot
      Comentar
    2. Dremel 4000 Power Cord Replacement: passo 8, imagem 1 %32
      • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
      Pergunte ao FixBot
      Comentar
    3. Dremel 4000 Power Cord Replacement: passo 9, imagem 1 %32
      • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
      • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
      Pergunte ao FixBot
      Comentar
    4. Dremel 4000 Power Cord Replacement: passo 10, imagem 1 %32
      • Carefully remove both wires from circuit board with your hands.
      • Take careful note of which side has the black wire and which has the white wire.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
John Cobb
Membro desde: 01/20/16
1.842 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 15-4, Remmell Spring 2016 Membro de USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Membros
Autoria de 28 guias
1Comentário do guia
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 84
Ao todo: 7,594
