Ir para o conteúdo principal
Dreamcast CMOS Battery Replacement
O que você precisa
  1. Dreamcast CMOS Battery Replacement, Top Cover: passo 1, imagem 1 %32
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
    Pergunte ao FixBot
    Comentar
  2. Dreamcast CMOS Battery Replacement: passo 2, imagem 1 %32
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
    Pergunte ao FixBot
    Comentar
  3. Dreamcast CMOS Battery Replacement, Controller Port: passo 3, imagem 1 %32 Dreamcast CMOS Battery Replacement, Controller Port: passo 3, imagem 2 %32
    • Be gentle with the white controller cable as it can be a bit fragile.
    • Disconnect the white controller cable by gently pulling the the cable while wiggling it back and forth until it detaches from the controller board.
    Pergunte ao FixBot
    Comentar
  4. Dreamcast CMOS Battery Replacement: passo 4, imagem 1 %32 Dreamcast CMOS Battery Replacement: passo 4, imagem 2 %32
    • Remove the four 14mm Philips #02 screws located on the controller board.
    Pergunte ao FixBot
    Comentar
  5. Dreamcast CMOS Battery Replacement: passo 5, imagem 1 %32 Dreamcast CMOS Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the white fan header from the controller port.
    Pergunte ao FixBot
    Comentar
  6. Dreamcast CMOS Battery Replacement: passo 6, imagem 1 %32 Dreamcast CMOS Battery Replacement: passo 6, imagem 2 %32
    • Remove the controller board by lifting it up from the controller port.
    Pergunte ao FixBot
    Comentar
  7. Dreamcast CMOS Battery Replacement, CMOS Battery: passo 7, imagem 1 %32
    • Note where the positive and negative terminals go.
    • Desolder the old CMOS battery from the controller board.
    Pergunte ao FixBot
    Comentar
  8. Dreamcast CMOS Battery Replacement: passo 8, imagem 1 %32
    • Solder the replacement battery holder to two electrical wires.
    • Solder the opposite ends of the wires to the controller board. Make sure to match corresponding points on the board with where the previous positive and negative terminals were.
    Pergunte ao FixBot
    Comentar
  9. Dreamcast CMOS Battery Replacement: passo 9, imagem 1 %32
    • Reinsert the controller board.
    • Attach the battery holder inside with a self adhesive substance, such as double sided foam tape.
    • Insert the battery into the battery holder.
    • Reverse the disassembly directions to reassemble your Dreamcast.
    • Once your Dreamcast is reassembled, go ahead and connect the Dreamcast to your TV or monitor and power, and reset the clock.
    Pergunte ao FixBot
    Comentar
Conclusão
18 outras pessoas executaram este guia.
Dark Sakul
Membro desde: 05/14/10
855 Reputação
Autoria de 1 guia
9Comentários do guia
For the step 7, you can get the cmos holder like this from ebay. This holder is perfect fit for the dreamcast controller board and easily replace the cmos battery if it drains out again.
leat - Responder Compartilhar
Just as a heads up, the coin cell that was pictured in this guide (a CR2025 from what I can see) is not rechargeable. The stock battery is an ML2430, so a suitable replacement of about the same size as a CR2025 would be cells with the code ML20XX (ML2020, ML2025, ML2032).
Elanna - Responder Compartilhar
Something that should be noted, even if the pictures kind of hint at it, is that the power board - the large board to the left of the console in Step 3, picture 1 - needs to be removed BEFORE the controller board can be taken out. On my DC the pins that connect the power board to the motherboard have a surprisingly strong grip, so I needed to pull up on that end with some force to get it off. Definitely something to be careful with, as you don't want those pins getting bent out of shape, never mind broken.
HGB - Responder Compartilhar
You can still use something like a CR2025, just wire a diode on the power line. Something like 1N581 or 1N5711 will work.
M. Guy - Responder Compartilhar
Dont use non rechargeble batteries. you can replace it with the little square batteries you found in chinese mp3 headphones… they’re 3.7v, 2000mah and are perfect for the console. This kind of lithium polimer batteries tend to hold charge for as much as six months according to my experience. And they’re easy available, if you can’t find one, just purchase those little chinese micro SD mp3 players/headphones , they’ll have one of this kind inside. Be sure the voltage is 3.7 at a maximum 2.000 mah
toniremords - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 128
Últimos 30 dias: 632
Ao todo: 96,608
