Ir para o conteúdo principal
Dreamax DMX-ST7A Motherboard Replacement
O que você precisa
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: passo 3, imagem 1 %32 Dreamax DMX-ST7A Motherboard Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: passo 4, imagem 1 %32
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: passo 6, imagem 1 %32 Dreamax DMX-ST7A Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: passo 7, imagem 1 %32 Dreamax DMX-ST7A Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: passo 8, imagem 1 %32 Dreamax DMX-ST7A Motherboard Replacement: passo 8, imagem 2 %32
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: Como soldar e dessoldar contatos
Conclusão
Uma outra pessoa concluiu este guia.
Stacey Mattila
Membro desde: 03/18/15
543 Reputação
Autoria de 5 guias
Equipe
Michigan Tech, Team 1-4, Lauer Spring 2015 Membro de Michigan Tech, Team 1-4, Lauer Spring 2015
MTU-LAUER-S15S1G4
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 321
