Ir para o conteúdo principal
Dragon Touch Y88X Plus Motherboard Replacement
O que você precisa
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: passo 2, imagem 1 %32
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: passo 3, imagem 1 %32
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: passo 4, imagem 1 %32 Dragon Touch Y88X Plus Motherboard Replacement: passo 4, imagem 2 %32
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: passo 5, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: passo 6, imagem 1 %32
    • Gently lift the motherboard from the device.
Conclusão
Cody Camara
Membro desde: 11/01/23
149 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 63
