Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide walks through the process to replace the back speakers on the device. For safety reasons, you must first disconnect the battery from the device. After the battery is removed, you can follow the rest of the directions to replace the speakers safely.
  1. Insert the plastic opening tool between the white back cover and black front over.
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover. You may need to pry the back cover off using the opening tool while moving it along the edge.
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  5. Use the hair dryer to melt the glue holding the battery to the device.
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  6. Insert the plastic card under the battery and use it to remove the battery from the device.
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  7. Desolder the red and black wires connecting the battery to the motherboard and remove the battery. Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  8. Desolder the red and black wires connecting each speaker to the motherboard. Desolder the red and black wires connecting each speaker to the motherboard. Desolder the red and black wires connecting each speaker to the motherboard.
    • Desolder the red and black wires connecting each speaker to the motherboard.
Conclusão
Josh Null
Membro desde: 21-03-2018
313 Reputação
3 Guias de autoria
Equipe
IUPUI, Team S5-G5, Baechle Spring 2018 Membro de IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Membros
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 73
