Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert the plastic opening tool between the white back cover and black front over.
Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
Use the hair dryer to melt the glue holding the battery to the device.
Ferramenta utilizada nesse passo:Plastic Cards$2.99-
Insert the plastic card under the battery and use it to remove the battery from the device.
Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
Remove black tape holding the cameras to the motherboard.
Use your fingernail to flip up the small locking flap on the ZIF connector.
Pull the ribbon cable from the ZIF connector.
Remove the front camera from the device using your fingers.
Melt the glue holding the rear camera in place using a hair dryer.
Insert the metal spludger under the rear camera and pry it free from the device.
