Ir para o conteúdo principal
Dragon Touch A1x Plus Cameras Replacement
O que você precisa
  1. Dragon Touch A1x Plus Cameras Replacement, Battery: passo 1, imagem 1 %32
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Cameras Replacement: passo 2, imagem 1 %32 Dragon Touch A1x Plus Cameras Replacement: passo 2, imagem 2 %32
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Cameras Replacement: passo 3, imagem 1 %32
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Cameras Replacement: passo 4, imagem 1 %32
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Cameras Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Cameras Replacement: passo 6, imagem 1 %32 Dragon Touch A1x Plus Cameras Replacement: passo 6, imagem 2 %32
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  7. Dragon Touch A1x Plus Cameras Replacement, Cameras: passo 7, imagem 1 %32 Dragon Touch A1x Plus Cameras Replacement, Cameras: passo 7, imagem 2 %32
    • Remove black tape holding the cameras to the motherboard.
  8. Dragon Touch A1x Plus Cameras Replacement: passo 8, imagem 1 %32 Dragon Touch A1x Plus Cameras Replacement: passo 8, imagem 2 %32
    • Use your fingernail to flip up the small locking flap on the ZIF connector.
    • Pull the ribbon cable from the ZIF connector.
  9. Dragon Touch A1x Plus Cameras Replacement: passo 9, imagem 1 %32
    • Remove the front camera from the device using your fingers.
  10. Dragon Touch A1x Plus Cameras Replacement: passo 10, imagem 1 %32 Dragon Touch A1x Plus Cameras Replacement: passo 10, imagem 2 %32
    • Melt the glue holding the rear camera in place using a hair dryer.
    • Insert the metal spludger under the rear camera and pry it free from the device.
Conclusão
Josh Null
Membro desde: 03/21/18
313 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S5-G5, Baechle Spring 2018 Membro de IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 265
