Ir para o conteúdo principal
Dopo Double Power 7 Battery Replacement
O que você precisa
  1. Dopo Double Power 7 Battery Replacement, Rear Panel: passo 1, imagem 1 %32
    • The rear panel is secured to the front case and can simply be pried apart without damage.
    Pergunte ao FixBot
    Comentar
  2. Dopo Double Power 7 Battery Replacement: passo 2, imagem 1 %32
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
    Pergunte ao FixBot
    Comentar
  3. Dopo Double Power 7 Battery Replacement: passo 3, imagem 1 %32
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
    Pergunte ao FixBot
    Comentar
  4. Dopo Double Power 7 Battery Replacement: passo 4, imagem 1 %32
    • The rear panel should come completely off.
    Pergunte ao FixBot
    Comentar
  5. Dopo Double Power 7 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Cut only the red and black wires attaching the battery to the motherboard.
    • Be sure to remove any remaining wire attached to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Dopo Double Power 7 Battery Replacement: passo 6, imagem 1 %32
    • Using a metal spudger, carefully pry the battery away from the digitizer.
    • Be careful to not damage the battery. This could result in injury.
    Pergunte ao FixBot
    Comentar
  7. Dopo Double Power 7 Battery Replacement: passo 7, imagem 1 %32
    • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
    • Twist the strands of the spliced wire together.
    • Using a soldering iron, apply heat to one bare wire connections you have just made.
    • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
    • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
    • Repeat this process with the other wire.
    • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
    • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
mike pelosi
Membro desde: 10/30/15
682 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-2, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 1,325
