Introdução
This guide will walk you through on the steps on replacing your door mirror. You will need to be careful with handling the mirror, as it could potentially shattered if not handled properly. The tools that you will need for this is just screwdriver, but a power drill can also be used.
O que você precisa
Use a screwdriver to remove the two brackets securing the top of the mirror.
Conclusão
Enjoy your new mirror!
