Ir para o conteúdo principal
Disassembling the Linksys E1200
O que você precisa
    1. Disassembling the Linksys E1200, Cover and Circuit Board: passo 1, imagem 1 %32 Disassembling the Linksys E1200, Cover and Circuit Board: passo 1, imagem 2 %32 Disassembling the Linksys E1200, Cover and Circuit Board: passo 1, imagem 3 %32
      • Opening the device will void your warranty.
      • Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
      • Remove the three screws.
      • Save the pads for reassembly.
      Pergunte ao FixBot
      Comentar
    2. Disassembling the Linksys E1200: passo 2, imagem 1 %32 Disassembling the Linksys E1200: passo 2, imagem 2 %32 Disassembling the Linksys E1200: passo 2, imagem 3 %32
      • Once the three screws are removed, the device is ready for disassembly.
      • Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
      • Insert the plastic opening tool in the gap and begin prying on the corner.
      • Continue to pry around the body of the case. Separate both sides of the case with this method.
      Pergunte ao FixBot
      Comentar
    3. Disassembling the Linksys E1200: passo 3, imagem 1 %32 Disassembling the Linksys E1200: passo 3, imagem 2 %32
      • Once the sides are released, the front of the cover can be removed.
      • Use a plastic opening tool to separate the front of the cover from the body.
      • It is helpful to use a different plastic opening tool as a wedge on the sides to prevent them from snapping back together.
      Pergunte ao FixBot
      Comentar
    4. Disassembling the Linksys E1200: passo 4, imagem 1 %32 Disassembling the Linksys E1200: passo 4, imagem 2 %32 Disassembling the Linksys E1200: passo 4, imagem 3 %32
      • The cover can now be removed.
      • To repair anything on the circuit board, use the plastic opening tool to pull back on the two tabs holding it down.
      • Use caution when pulling on the tabs as they are stiff and easy to break.
      • Keep the tabs if they snap off. The tabs can be reattached with glue when reassembling the device.
      Pergunte ao FixBot
      Comentar
    5. Disassembling the Linksys E1200: passo 5, imagem 1 %32 Disassembling the Linksys E1200: passo 5, imagem 2 %32 Disassembling the Linksys E1200: passo 5, imagem 3 %32
      • If the antenna needs to be disconnected, desolder the connection and reattach it prior to reassembly.
      • If the ethernet ports, power port, or reset button are damaged, the large solder points allow you to replace them.
      • Many components on the board cannot be serviced. These components were attached by a machine and cannot be removed.
      Pergunte ao FixBot
      Comentar
Conclusão
13 outras pessoas executaram este guia.
Equipe
Michigan Tech, Team 5-4, Lauer Spring 2014 Membro de Michigan Tech, Team 5-4, Lauer Spring 2014
MTU-LAUER-S14S5G4
3 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 45
Ao todo: 7,765
