Ir para o conteúdo principal
Disassembling Wii Balance Board
O que você precisa
    1. Disassembling Wii Balance Board, Floor Unit: passo 1, imagem 1 %32
      • Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Wii Balance Board: passo 2, imagem 1 %32
      • Remove the foot holders and place them on the side
      Pergunte ao FixBot
      Comentar
    3. Disassembling Wii Balance Board: passo 3, imagem 1 %32
      • Remove the four feet and place them on the side
      Pergunte ao FixBot
      Comentar
    4. Disassembling Wii Balance Board: passo 4, imagem 1 %32
      • Remove these #1 Philips screws, and leave them in their counterbores
      Pergunte ao FixBot
      Comentar
    5. Disassembling Wii Balance Board: passo 5, imagem 1 %32
      • Lift grey shell off and place to the side to reveal:
      • ADC and Logic board
      • Bluetooth module
      • Strain gauges
      • Battery holder
      Pergunte ao FixBot
      Comentar
    6. Disassembling Wii Balance Board: passo 6, imagem 1 %32
      • The ADC and Logic board contains:
      • Bluetooth module
      • Power button connector
      • Battery and sync button connector
      • Strain gauge wheatstone bridge connections
      • The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
      Pergunte ao FixBot
      Comentar
Conclusão
15 outras pessoas executaram este guia.
Pete Marchetto
Membro desde: 01/25/11
667 Reputação
Autoria de 2 guias
5Comentários do guia
Great stuff Pete, being able to fix the wifi board got me mucho street cred with " her indoors " and lots of other goodies that go along with that
HENRY - Responder Compartilhar
Can I take out the battery box without removing the bottom?
Richard Merchant - Responder Compartilhar
No, you can't. You will have to follow this procedure completely.
paulo lima - Responder Compartilhar
Thank you! I was able to fix our 10 year old balance board.
the kids think I’m a roakstar, for now anyway.
lisadubya - Responder Compartilhar
is there schematics for the power pcb
Josué Hernandez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 92
Ao todo: 13,904
