Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Oregon Scientific Ultra Thin Weather Station, use o nosso manual de serviço.
  1. Disassembling Weather Box Oregon BAR800, Disassembling Weather Box Oregon BAR800: passo 1, imagem 1 %32
    • Weather Box, front side
    Pergunte ao FixBot
    Comentar
  2. Disassembling Weather Box Oregon BAR800: passo 2, imagem 1 %32 Disassembling Weather Box Oregon BAR800: passo 2, imagem 2 %32 Disassembling Weather Box Oregon BAR800: passo 2, imagem 3 %32
    • Rear side
    Pergunte ao FixBot
    Comentar
  3. Disassembling Weather Box Oregon BAR800: passo 3, imagem 1 %32
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
    Pergunte ao FixBot
    Comentar
  4. Disassembling Weather Box Oregon BAR800: passo 4, imagem 1 %32 Disassembling Weather Box Oregon BAR800: passo 4, imagem 2 %32 Disassembling Weather Box Oregon BAR800: passo 4, imagem 3 %32
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Weather Box Oregon BAR800: passo 5, imagem 1 %32
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Weather Box Oregon BAR800: passo 6, imagem 1 %32 Disassembling Weather Box Oregon BAR800: passo 6, imagem 2 %32 Disassembling Weather Box Oregon BAR800: passo 6, imagem 3 %32
    • Internal view
    Pergunte ao FixBot
    Comentar
Andres
Membro desde: 11/14/13
110 Reputação
Autoria de 1 guia
10Comentários do guia
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Responder Compartilhar
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel - Responder Compartilhar
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic - Responder Compartilhar
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V - Responder Compartilhar
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 3,880
