Ir para o conteúdo principal
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
O que você precisa
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: passo 1, imagem 1 %32
    • Remove the battery covers and the four batteries.
    Pergunte ao FixBot
    Comentar
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 2, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 2, imagem 2 %32
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
    Pergunte ao FixBot
    Comentar
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 3, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 3, imagem 2 %32
    • Using a plastic opening tool, separate the two pieces of the case carefully.
    Pergunte ao FixBot
    Comentar
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, imagem 1 %32
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
    Pergunte ao FixBot
    Comentar
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 5, imagem 1 %32
    • Remove the three "L" shaped brackets and the spring.
    Pergunte ao FixBot
    Comentar
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 6, imagem 1 %32
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
    Pergunte ao FixBot
    Comentar
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 7, imagem 1 %32
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
    Pergunte ao FixBot
    Comentar
Conclusão
Daniel Kresge
Membro desde: 09/01/15
385 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membros
Autoria de 17 guias
1Comentário do guia
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 43
Ao todo: 2,723
