Ir para o conteúdo principal
Disassembling VTech MobiGo Touch Learning System Keyboard
O que você precisa
  1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: passo 1, imagem 1 %32
    • Remove the battery covers and the four batteries.
    Pergunte ao FixBot
    Comentar
  2. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 2, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 2, imagem 2 %32
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
    Pergunte ao FixBot
    Comentar
  3. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 3, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 3, imagem 2 %32
    • Using a plastic opening tool, separate the two pieces of the case carefully.
    Pergunte ao FixBot
    Comentar
  4. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: passo 4, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: passo 4, imagem 2 %32
    • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
    • Use light pressure to prevent damage to the circuit board.
    Pergunte ao FixBot
    Comentar
  5. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 5, imagem 1 %32
    • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
    • Once the screw is removed, remove the blue plastic cover.
    Pergunte ao FixBot
    Comentar
  6. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 6, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 6, imagem 2 %32
    • Remove the two 4.0 mm Philips J0 screws located on the orange case.
    • Use gentle force to prevent stripping of screws.
    Pergunte ao FixBot
    Comentar
  7. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, imagem 2 %32 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 7, imagem 3 %32
    • Remove the two "L" shaped brackets located on both sides of the device.
    • Use the magnetic mat to store these brackets.
    Pergunte ao FixBot
    Comentar
  8. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 8, imagem 1 %32
    • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
    Pergunte ao FixBot
    Comentar
  9. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 9, imagem 1 %32 Disassembling VTech MobiGo Touch Learning System Keyboard: passo 9, imagem 2 %32
    • Gently lift the circuit board from the case using a plastic opening tool.
    • Make sure to use a plastic opening tool for this step.
    Pergunte ao FixBot
    Comentar
  10. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 10, imagem 1 %32
    • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
    • Keep the circuit board out of the way to avoid damaging it.
    Pergunte ao FixBot
    Comentar
  11. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 11, imagem 1 %32
    • Slowly remove the keyboard panel.
    • Use a spudger if necessary.
    • The keys will fall out once the keyboard panel is removed.
    • Remove all of the keys and set them aside with the keyboard panel.
    Pergunte ao FixBot
    Comentar
  12. Disassembling VTech MobiGo Touch Learning System Keyboard: passo 12, imagem 1 %32
    • Gently remove the keyboard circuit board with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
RBansil
Membro desde: 08/27/15
221 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro de USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membros
Autoria de 17 guias
1Comentário do guia
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 2,399
