Ir para o conteúdo principal
Disassembling Samsung Captivate Glide Phone
O que você precisa
  1. Disassembling Samsung Captivate Glide Phone, Phone: passo 1, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Phone: passo 1, imagem 2 %32 Disassembling Samsung Captivate Glide Phone, Phone: passo 1, imagem 3 %32
    • The Samsung Captivate Glide is fairly easy to take apart and replace any of the modular internal components
    Pergunte ao FixBot
    Comentar
  2. Disassembling Samsung Captivate Glide Phone, Battery Removal: passo 2, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Battery Removal: passo 2, imagem 2 %32 Disassembling Samsung Captivate Glide Phone, Battery Removal: passo 2, imagem 3 %32
    • First remove the battery
    Pergunte ao FixBot
    Comentar
  3. Disassembling Samsung Captivate Glide Phone, Unscrewing the Back: passo 3, imagem 1 %32
    • Using the Phillips #00 screwdriver remove the seven screws indicated here.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Samsung Captivate Glide Phone, Prying Up The Back: passo 4, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Prying Up The Back: passo 4, imagem 2 %32 Disassembling Samsung Captivate Glide Phone, Prying Up The Back: passo 4, imagem 3 %32
    • Plastic molded clips hold the back panel in place and can be removed by first inserting the plastic opening tool into the indicated locations and prying up to pop the back up.
    • Then using a wider lipped plastic opening tool pry the outside of the housing up and the back will remove cleanly.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Samsung Captivate Glide Phone, The Phone's Innards: passo 5, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, The Phone's Innards: passo 5, imagem 2 %32 Disassembling Samsung Captivate Glide Phone, The Phone's Innards: passo 5, imagem 3 %32
    • Shown here are internals of the phone.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Samsung Captivate Glide Phone, Motherboard Removal: passo 6, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: passo 6, imagem 2 %32 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: passo 6, imagem 3 %32
    • In order to remove the motherboard remove a single screw with the phillips #00 screwdriver, gently pry up the two pop connectors on the board, and finally pull off the coaxial cable.
    Pergunte ao FixBot
    Comentar
  7. Disassembling Samsung Captivate Glide Phone, Motherboard Removal: passo 7, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: passo 7, imagem 2 %32
    • The motherboard comes out of the phone body easily.
    Pergunte ao FixBot
    Comentar
  8. Disassembling Samsung Captivate Glide Phone, Daughterboard Removal: passo 8, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Daughterboard Removal: passo 8, imagem 2 %32
    • The modular pieces of the motherboard are easily removed and replaced as needed.
    • First the daughter board containing the SIM card and microSD card can be removed by disconnecting a single pop connector from the board and then gently pry the daughter board up and it will come loose. It is held down to the motherboard by the stamped metal board level shielding cages.
    Pergunte ao FixBot
    Comentar
  9. Disassembling Samsung Captivate Glide Phone, Camera Removal: passo 9, imagem 1 %32
    • The camera can be easily removed from the motherboard by pulling up on the board pop connector.
    Pergunte ao FixBot
    Comentar
  10. Disassembling Samsung Captivate Glide Phone, Speaker Removal: passo 10, imagem 1 %32
    • The speaker is also easily removed by pulling up on the pop connector.
    Pergunte ao FixBot
    Comentar
  11. Disassembling Samsung Captivate Glide Phone, The Disassembled Motherboard: passo 11, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, The Disassembled Motherboard: passo 11, imagem 2 %32
    • Shown here are all the pieces of the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: passo 12, imagem 1 %32 Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: passo 12, imagem 2 %32 Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: passo 12, imagem 3 %32
    • The antenna module can be removed by disconnecting the coaxial cable and a single phillips #00 screw.
    • The antenna module can be prying upward at the location indicated.
    Pergunte ao FixBot
    Comentar
  13. Disassembling Samsung Captivate Glide Phone, Antenna Module: passo 13, imagem 1 %32
    • Shown here is the antenna module.
    Pergunte ao FixBot
    Comentar
  14. Disassembling Samsung Captivate Glide Phone, Base and Screen: passo 14, imagem 1 %32
    • The screen and base are shown here.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
alcs99
Membro desde: 09/10/13
5.075 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 39
Ao todo: 3,879
