Ir para o conteúdo principal
Disassembling REL T5 Transformer
O que você precisa
  1. Disassembling REL T5 Transformer, Remove screws: passo 1, imagem 1 %32 Disassembling REL T5 Transformer, Remove screws: passo 1, imagem 2 %32 Disassembling REL T5 Transformer, Remove screws: passo 1, imagem 3 %32
    • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
    • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
    • Make sure to support the plate amp by gripping the heat sink.
    • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
    • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
    Pergunte ao FixBot
    Comentar
  2. Disassembling REL T5 Transformer, Disconnect the driver: passo 2, imagem 1 %32 Disassembling REL T5 Transformer, Disconnect the driver: passo 2, imagem 2 %32
    • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
    Pergunte ao FixBot
    Comentar
  3. Disassembling REL T5 Transformer, Remove plate amp: passo 3, imagem 1 %32
    • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
    • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
    Pergunte ao FixBot
    Comentar
  4. Disassembling REL T5 Transformer, Snip all connecting trywraps: passo 4, imagem 1 %32 Disassembling REL T5 Transformer, Snip all connecting trywraps: passo 4, imagem 2 %32
    • Snip all tywraps, such that all cables can be manipulated freely.
    Pergunte ao FixBot
    Comentar
  5. Disassembling REL T5 Transformer, Disconnect connectors: passo 5, imagem 1 %32 Disassembling REL T5 Transformer, Disconnect connectors: passo 5, imagem 2 %32
    • Disconnect all connectors that tie to the transformer
    • Make sure that all leads can be manipulated freely.
    Pergunte ao FixBot
    Comentar
  6. Disassembling REL T5 Transformer, Loosen screws: passo 6, imagem 1 %32 Disassembling REL T5 Transformer, Loosen screws: passo 6, imagem 2 %32
    • Start loosening the screws on the back using the m3 hex tool
    • Don't remove them fully, yet though.
    Pergunte ao FixBot
    Comentar
  7. Disassembling REL T5 Transformer, Remove screws: passo 7, imagem 1 %32 Disassembling REL T5 Transformer, Remove screws: passo 7, imagem 2 %32
    • Turn the amp on it's back.
    • Remove the nuts from the screws that where loosened on the back.
    • Remove the philips screws using a #2.
    Pergunte ao FixBot
    Comentar
  8. Disassembling REL T5 Transformer, Loosen dampening rubber: passo 8, imagem 1 %32
    • Loosen the dampening rubber by running a Halberd Spudger underneath it.
    • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
    Pergunte ao FixBot
    Comentar
  9. Disassembling REL T5 Transformer, Remove transformer: passo 9, imagem 1 %32 Disassembling REL T5 Transformer, Remove transformer: passo 9, imagem 2 %32
    • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
    Pergunte ao FixBot
    Comentar
Conclusão
Jasper van Zuijlen
Membro desde: 04/21/25
1.044 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 24
Ao todo: 24
