Ir para o conteúdo principal
Disassembling RCA CC310 Left Cover
O que você precisa
    1. Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: passo 1, imagem 1 %32 Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: passo 1, imagem 2 %32
      • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
      • Remove the one 3.8mm Phillips #0 screw on the bottom.
      • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
      Pergunte ao FixBot
      Comentar
    2. Disassembling RCA CC310 Left Cover: passo 2, imagem 1 %32 Disassembling RCA CC310 Left Cover: passo 2, imagem 2 %32
      • Remove 5.8mm Phillips #1 screw from the side button panel.
      • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
      Pergunte ao FixBot
      Comentar
    3. Disassembling RCA CC310 Left Cover: passo 3, imagem 1 %32 Disassembling RCA CC310 Left Cover: passo 3, imagem 2 %32
      • Pry along the seam on the top side near the buttons with a spudger.
      Pergunte ao FixBot
      Comentar
    4. Disassembling RCA CC310 Left Cover: passo 4, imagem 1 %32 Disassembling RCA CC310 Left Cover: passo 4, imagem 2 %32
      • Pull the left panel away from the rest of the camcorder.
      • Unplug the red speaker cable located at the rear of the device.
      • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 5-20, Amido Winter 2011 Membro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membros
Autoria de 70 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,540
