Ir para o conteúdo principal
Disassembling Polaroid a520 Lens
O que você precisa
    1. Disassembling Polaroid a520 Lens, Battery: passo 1, imagem 1 %32 Disassembling Polaroid a520 Lens, Battery: passo 1, imagem 2 %32
      • Place your thumb on the battery cover and push left towards the arrow.
      • The cover will release and pop open.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Polaroid a520 Lens: passo 2, imagem 1 %32
      • Remove the batteries from the camera.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Polaroid a520 Lens, Casing: passo 3, imagem 1 %32
      • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
      • This will release the front and back casings.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Polaroid a520 Lens: passo 4, imagem 1 %32
      • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
      • Repeat this step for the back casing.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Polaroid a520 Lens, LCD Screen: passo 5, imagem 1 %32
      • Under the screen, locate the black plastic strip that sits above the white plastic strip.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Polaroid a520 Lens: passo 6, imagem 1 %32
      • Pull both sides of the black piece upward-about a mm.
      • The black plastic piece is not meant to come all the way off, just enough to release the screen.
      • Once the piece is lifted carefully slide the screen out of the slot.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Polaroid a520 Lens, Logic Board: passo 7, imagem 1 %32
      • Unscrew and remove the four (6 mm) screws on the inside casing.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Polaroid a520 Lens: passo 8, imagem 1 %32
      • Pull the inner casing off of the camera.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Polaroid a520 Lens: passo 9, imagem 1 %32
      • Unscrew and remove the four (4mm) screws from the logic board.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Polaroid a520 Lens: passo 10, imagem 1 %32
      • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Polaroid a520 Lens, Lens: passo 11, imagem 1 %32
      • Unscrew and remove the two (5mm) screws from the logic board to the far left.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Polaroid a520 Lens: passo 12, imagem 1 %32
      • Locate the black plastic piece behind the lens.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Polaroid a520 Lens: passo 13, imagem 1 %32
      • Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
      • The piece will not come all the way off; only enough to release the lens.
      • Once the black piece is lifted slide the ribbon out to release the lens.
      Pergunte ao FixBot
      Comentar
Conclusão
Dani
Membro desde: 06/24/10
21 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 3-3, Johann Summer 2010 Membro de Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Membros
Autoria de 21 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 20
Ao todo: 1,418
