Introdução
This guide will show you how to separate the body into the trigger frame and the bolt frame. This will allow you to access the solenoid and eyes.
O que você precisa
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
