Ir para o conteúdo principal
Disassembling Planet Eclipse Etha Frame
O que você precisa
    1. Disassembling Planet Eclipse Etha Frame, Regulator: passo 1, imagem 1 %32 Disassembling Planet Eclipse Etha Frame, Regulator: passo 1, imagem 2 %32
      • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
      • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
      • The macroline is the black hose connecting the regulator to the tank connection.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Planet Eclipse Etha Frame: passo 2, imagem 1 %32 Disassembling Planet Eclipse Etha Frame: passo 2, imagem 2 %32
      • Remove the regulator by unscrewing it in a clockwise direction.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: passo 3, imagem 1 %32 Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: passo 3, imagem 2 %32
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Planet Eclipse Etha Frame: passo 4, imagem 1 %32
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Planet Eclipse Etha Frame: passo 5, imagem 1 %32 Disassembling Planet Eclipse Etha Frame: passo 5, imagem 2 %32
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Planet Eclipse Etha Frame, Frame: passo 6, imagem 1 %32 Disassembling Planet Eclipse Etha Frame, Frame: passo 6, imagem 2 %32
      • Carefully disconnect the three connectors from the circuit board.
      • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Planet Eclipse Etha Frame: passo 7, imagem 1 %32 Disassembling Planet Eclipse Etha Frame: passo 7, imagem 2 %32
      • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Planet Eclipse Etha Frame: passo 8, imagem 1 %32
      • Be very careful during the step to avoid damage to the solenoid or wiring.
      • Gently separate the top and bottom of the marker.
      Pergunte ao FixBot
      Comentar
Conclusão
nicholasj6
Membro desde: 10/14/14
261 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-42, Amido Fall 2014 Membro de Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 28
Ao todo: 681
