Ir para o conteúdo principal
Disassembling Optoma HD20 Cover
O que você precisa
  1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: passo 1, imagem 1 %32 Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: passo 1, imagem 2 %32
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Optoma HD20 Cover: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Optoma HD20 Cover: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Optoma HD20 Cover: passo 4, imagem 1 %32
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Trever
Membro desde: 01/22/15
1.282 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-23, Maness Winter 2015 Membro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 44
Ao todo: 3,814
