Ir para o conteúdo principal
Disassembling Olympus Stylus 725 SW Battery
  1. Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: passo 1, imagem 1 %32 Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: passo 1, imagem 2 %32
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
    Pergunte ao FixBot
    Comentar
Conclusão
Follow these instructions in reverse order to reassemble your device.
Bobby Hodges
Membro desde: 04/18/10
49 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 33-71, Johann Spring 2010 Membro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 72
Ao todo: 4,083
