Ir para o conteúdo principal
Disassembling Olympus Stylus 725 SW Back Panel
O que você precisa
    1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: passo 1, imagem 1 %32 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: passo 1, imagem 2 %32
      • The battery is located on the bottom of the camera.
      • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
      • If the battery is dead, charge it for 60-90 minutes.
      • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: passo 2, imagem 1 %32 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: passo 2, imagem 2 %32 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: passo 2, imagem 3 %32
      • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
      • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Olympus Stylus 725 SW Back Panel: passo 3, imagem 1 %32 Disassembling Olympus Stylus 725 SW Back Panel: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
      • Detach the ribbons using your thumb, sliding them out of their slots.
      • Set the back panel face up to keep the ribbons from touching anything.
      Pergunte ao FixBot
      Comentar
Conclusão
Bobby Hodges
Membro desde: 04/18/10
49 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 33-71, Johann Spring 2010 Membro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membros
Autoria de 72 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 109
Ao todo: 5,131
