Ir para o conteúdo principal
Disassembling Nokia 3395 Inner Components
O que você precisa
  1. Disassembling Nokia 3395 Inner Components, Back Case: passo 1, imagem 1 %32 Disassembling Nokia 3395 Inner Components, Back Case: passo 1, imagem 2 %32 Disassembling Nokia 3395 Inner Components, Back Case: passo 1, imagem 3 %32
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Nokia 3395 Inner Components, Battery: passo 2, imagem 1 %32 Disassembling Nokia 3395 Inner Components, Battery: passo 2, imagem 2 %32
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Nokia 3395 Inner Components, Front Case: passo 3, imagem 1 %32 Disassembling Nokia 3395 Inner Components, Front Case: passo 3, imagem 2 %32
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Nokia 3395 Inner Components, Screen: passo 4, imagem 1 %32 Disassembling Nokia 3395 Inner Components, Screen: passo 4, imagem 2 %32
    • Remove six T6 screws.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Nokia 3395 Inner Components: passo 5, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 5, imagem 2 %32
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Nokia 3395 Inner Components, Logic Board: passo 6, imagem 1 %32 Disassembling Nokia 3395 Inner Components, Logic Board: passo 6, imagem 2 %32
    • Remove logic board as shown.
    Pergunte ao FixBot
    Comentar
  7. Disassembling Nokia 3395 Inner Components, Inner Components: passo 7, imagem 1 %32
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
    Pergunte ao FixBot
    Comentar
  8. Disassembling Nokia 3395 Inner Components: passo 8, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 8, imagem 2 %32
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
    Pergunte ao FixBot
    Comentar
  9. Disassembling Nokia 3395 Inner Components: passo 9, imagem 1 %32
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    Pergunte ao FixBot
    Comentar
  10. Disassembling Nokia 3395 Inner Components: passo 10, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 10, imagem 2 %32
    • Audio speaker.
    Pergunte ao FixBot
    Comentar
  11. Disassembling Nokia 3395 Inner Components: passo 11, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 11, imagem 2 %32
    • SIM card reader.
    Pergunte ao FixBot
    Comentar
  12. Disassembling Nokia 3395 Inner Components: passo 12, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 12, imagem 2 %32
    • Vibrating unit.
    Pergunte ao FixBot
    Comentar
  13. Disassembling Nokia 3395 Inner Components: passo 13, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 13, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  14. Disassembling Nokia 3395 Inner Components: passo 14, imagem 1 %32 Disassembling Nokia 3395 Inner Components: passo 14, imagem 2 %32
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nico Lee
Membro desde: 04/19/10
83 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 30-41, Garner Spring 2010 Membro de Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 3,338
