Ir para o conteúdo principal
Disassembling Nokia 3100b Speaker
O que você precisa
  1. Disassembling Nokia 3100b Speaker, Battery: passo 1, imagem 1 %32
    • Make sure your phone is turned off.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Nokia 3100b Speaker: passo 2, imagem 1 %32
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Nokia 3100b Speaker, SIM Card: passo 3, imagem 1 %32
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Nokia 3100b Speaker: passo 4, imagem 1 %32
    • Retrieve your SIM card.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Nokia 3100b Speaker, Screen: passo 5, imagem 1 %32
    • Separate the front cover from the main body of the phone.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Nokia 3100b Speaker: passo 6, imagem 1 %32
    • Remove the six screws along the edges of the phone.
    Pergunte ao FixBot
    Comentar
  7. Disassembling Nokia 3100b Speaker: passo 7, imagem 1 %32
    • Pull the screen assembly from the base of the phone.
    Pergunte ao FixBot
    Comentar
  8. Disassembling Nokia 3100b Speaker: passo 8, imagem 1 %32
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
    Pergunte ao FixBot
    Comentar
  9. Disassembling Nokia 3100b Speaker: passo 9, imagem 1 %32
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
    Pergunte ao FixBot
    Comentar
  10. Disassembling Nokia 3100b Speaker: passo 10, imagem 1 %32
    • Gently push down on the screen to pop it off of the assembly.
    Pergunte ao FixBot
    Comentar
  11. Disassembling Nokia 3100b Speaker: passo 11, imagem 1 %32
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
    Pergunte ao FixBot
    Comentar
  12. Disassembling Nokia 3100b Speaker, Speaker: passo 12, imagem 1 %32
    • Set the screen and the tabs aside.
    Pergunte ao FixBot
    Comentar
  13. Disassembling Nokia 3100b Speaker: passo 13, imagem 1 %32
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
    Pergunte ao FixBot
    Comentar
  14. Disassembling Nokia 3100b Speaker: passo 14, imagem 1 %32
    • Remove the speaker from the assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 29-64, Johann Spring 2010 Membro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 45
Ao todo: 1,582
