Ir para o conteúdo principal
Disassembling Nerf Recon CS-6 Shell
O que você precisa
  1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: passo 1, imagem 1 %32
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: passo 2, imagem 1 %32
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: passo 3, imagem 1 %32 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: passo 3, imagem 2 %32
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: passo 4, imagem 1 %32
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: passo 5, imagem 1 %32
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: passo 6, imagem 1 %32 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: passo 6, imagem 2 %32
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Asad Qureshi
Membro desde: 10/22/14
595 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 8-14, Williams Fall 2014 Membro de Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Membros
Autoria de 6 guias
2Comentários do guia
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - Responder Compartilhar
very useful, thanks!
Sebastian Isaacs - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 49
Ao todo: 12,896
