Ir para o conteúdo principal
Disassembling Motorola i265 Rear Casing/Battery/SIM Card
O que você precisa
  1. Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: passo 1, imagem 1 %32 Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: passo 1, imagem 2 %32
    • Press thumb against the top of the rear casing as shown and push down as you slide the casing off of the body.
    • You should hear a click as the latches on the casing disengage.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: passo 2, imagem 1 %32 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: passo 2, imagem 2 %32 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: passo 2, imagem 3 %32
    • To remove the battery, press thumb against the bottom edge of the battery and push towards the top of the phone.
    • Then, lift the bottom edge of the battery upwards out of the body. Gently pull the battery towards yourself, and out of the phone.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: passo 3, imagem 1 %32 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: passo 3, imagem 2 %32 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: passo 3, imagem 3 %32
    • To remove SIM card, press thumb against tab marked “PUSH.”
    • While still pressing the PUSH tab, gently press spduger into the groove between the top of the SIM card and the body. Use spudger to slide SIM card toward the PUSH tab, so that when the spudger reaches the metal cover, the card itself is depressing the tab.
    • Press your thumb against the exposed section of the SIM card, and slide it towards the rear of the phone until it is completely free of the metal cover.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 6-15, Maness Spring 2010 Membro de Cal Poly, Team 6-15, Maness Spring 2010
CPSU-MANESS-S10S6G15
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 2,884
