Ir para o conteúdo principal
Disassembling Mac Powerbook 140 Keycaps
O que você precisa
  1. Disassembling Mac Powerbook 140 Keycaps, Takeing the caps off: passo 1, imagem 1 %32
    • The keycaps are connected via 2 clips on the left and the right side of the keycaps. Larger keycaps are connected to stabilizers, be careful when taking these caps off since the underlying plastic has overhangs that can break off.
    • Firstly pry the clip on one side with a spudger. Keep the open clip up while prying the other clip open. Be careful of the stabilizers when taking off larger caps.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Mac Powerbook 140 Keycaps, Take off underlying parts: passo 2, imagem 1 %32
    • The board still has the white springs and the silicone cone on it. Grab the white spring with tweezers or by hand and take it off. It has 2 clips on the top and on the bottom.
    • After removing the white part remove the silicone cone with tweezers.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Mac Powerbook 140 Keycaps, Putting the silicone rings back: passo 3, imagem 1 %32
    • First put the silicone rings on the circular pillars with a hole. Put the silicone rings with their widest part up.
    Pergunte ao FixBot
    Comentar
    • I found the easiest way to put these back is to put it on rotated to the left then spin it clockwise until it clicks.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: passo 5, imagem 1 %32 Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: passo 5, imagem 2 %32
    • To correctly orient the keycaps note, that the letters are on the bottom left of the keycaps. Also, the caps are rounder at the bottom. You can find the place for the white spring's arms on the back side of the keycaps.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow from the 3rd step.
Kristóf Kékesi
Membro desde: 12/16/25
121 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 58
