Ir para o conteúdo principal
Disassembling Logitech G27 Steering Wheel
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Disassembling Logitech G27 Steering Wheel, Steering Wheel: passo 1, imagem 1 %32
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Logitech G27 Steering Wheel: passo 2, imagem 1 %32
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Logitech G27 Steering Wheel: passo 3, imagem 1 %32
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Logitech G27 Steering Wheel: passo 4, imagem 1 %32
    • Carefully remove the PCB board from the wheel hub.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Logitech G27 Steering Wheel: passo 5, imagem 1 %32
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Logitech G27 Steering Wheel: passo 6, imagem 1 %32
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    Pergunte ao FixBot
    Comentar
  7. Disassembling Logitech G27 Steering Wheel: passo 7, imagem 1 %32
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  8. Disassembling Logitech G27 Steering Wheel: passo 8, imagem 1 %32
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    Pergunte ao FixBot
    Comentar
  9. Disassembling Logitech G27 Steering Wheel: passo 9, imagem 1 %32
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Disassembling Logitech G27 Steering Wheel: passo 10, imagem 1 %32
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    Pergunte ao FixBot
    Comentar
  11. Disassembling Logitech G27 Steering Wheel: passo 11, imagem 1 %32
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    Pergunte ao FixBot
    Comentar
  12. Disassembling Logitech G27 Steering Wheel: passo 12, imagem 1 %32
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  13. Disassembling Logitech G27 Steering Wheel: passo 13, imagem 1 %32 Disassembling Logitech G27 Steering Wheel: passo 13, imagem 2 %32
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    Pergunte ao FixBot
    Comentar
Conclusão
11 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 15-4, Amido Spring 2015 Membro de Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Membros
Autoria de 25 guias
1Comentário do guia
Hi - help please. I disassembled my G27 and a 2 inch long semicircular metal clip fell out during the process. I don’t know what it is or where it came from.
tony davies - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 37
Ao todo: 6,435
