Ir para o conteúdo principal
Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections
O que você precisa
    1. Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections, Interior Soldered Wire Connections: passo 1, imagem 1 %32
      • The back panel (pictured left) has a black wire (end of wire circled red). The wire solders to the bottom right corner of the card drive.
      • The front panel (pictured right) has a black and red wire (end of wired circled green). This wire solders to a small circular spot next to where the black wire connects to the back (from above).
      Pergunte ao FixBot
      Comentar
Conclusão
ewkpates
Membro desde: 05/03/12
133 Reputação
Autoria de 1 guia
2Comentários do guia
To open the leappad top start with, remove battery covers and the 6 screws.
The two halves slide, bottom half towards cartridge slot, to make it harder they have used double sided tape on the bottom platic tounges, so a scredriver in the bottom will be needed to prize the slide.
Lawrence - Responder Compartilhar
Good stuff. I'm trying to slide the back plate upward, but to no avail. You mentioned tape. Where exactly is it located?
John - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 45
Ao todo: 6,500
