Ir para o conteúdo principal
Disassembling JVC GR-D290U
O que você precisa
    1. Disassembling JVC GR-D290U, JVC GR-D290U: passo 1, imagem 1 %32 Disassembling JVC GR-D290U, JVC GR-D290U: passo 1, imagem 2 %32
      • Open the liquid-crystal display (LCD) screen.
      • Using a Phillips #1 screwdriver, remove the two hinge screws.
      • Remove the hinge cover. Shut the screen after the cover is removed.
      Pergunte ao FixBot
      Comentar
    2. Disassembling JVC GR-D290U: passo 2, imagem 1 %32 Disassembling JVC GR-D290U: passo 2, imagem 2 %32 Disassembling JVC GR-D290U: passo 2, imagem 3 %32
      • Flip the camera over to look at the bottom panel.
      • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
      • Push the eject button beneath the bottom panel to open the cassette cover.
      • Shut the cassette cover.
      • Place the camera upright.
      Pergunte ao FixBot
      Comentar
    3. Disassembling JVC GR-D290U: passo 3, imagem 1 %32
      • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
      • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
      • Replace the dark gray tab and close the LCD screen.
      Pergunte ao FixBot
      Comentar
    4. Disassembling JVC GR-D290U: passo 4, imagem 1 %32
      • Go to the side of the camera that is opposite the LCD screen.
      • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Disassembling JVC GR-D290U: passo 5, imagem 1 %32 Disassembling JVC GR-D290U: passo 5, imagem 2 %32
      • Go to the side of the camera that has the LCD screen.
      • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
      • Pry the top cover from the bottom cover until you hear a snapping sound.
      • Gently remove the top cover from the camera base.
      Pergunte ao FixBot
      Comentar
Conclusão
justin chen
Membro desde: 04/27/10
47 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-69, Johann Spring 2010 Membro de Cal Poly, Team 18-69, Johann Spring 2010
CPSU-JOHANN-S10S18G69
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 45
Ao todo: 4,676
