Ir para o conteúdo principal
Disassembling IBM WorkPad c3 LCD
O que você precisa
  1. Disassembling IBM WorkPad c3 LCD, Back Case: passo 1, imagem 1 %32 Disassembling IBM WorkPad c3 LCD, Back Case: passo 1, imagem 2 %32
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    Pergunte ao FixBot
    Comentar
  2. Disassembling IBM WorkPad c3 LCD: passo 2, imagem 1 %32
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    Pergunte ao FixBot
    Comentar
  3. Disassembling IBM WorkPad c3 LCD: passo 3, imagem 1 %32 Disassembling IBM WorkPad c3 LCD: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    Pergunte ao FixBot
    Comentar
  4. Disassembling IBM WorkPad c3 LCD, Front Case: passo 4, imagem 1 %32 Disassembling IBM WorkPad c3 LCD, Front Case: passo 4, imagem 2 %32
    • Turn the device over, so that the screen is laying on a flat surface.
    Pergunte ao FixBot
    Comentar
  5. Disassembling IBM WorkPad c3 LCD: passo 5, imagem 1 %32 Disassembling IBM WorkPad c3 LCD: passo 5, imagem 2 %32 Disassembling IBM WorkPad c3 LCD: passo 5, imagem 3 %32
    • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
    • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
    • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
    Pergunte ao FixBot
    Comentar
  6. Disassembling IBM WorkPad c3 LCD: passo 6, imagem 1 %32 Disassembling IBM WorkPad c3 LCD: passo 6, imagem 2 %32
    • The device will be extremely hot. Use a towel or oven mitt to grab it.
    • Using the Plastic Opening Tools, take the front of the case off.
    • If the case is difficult to remove, try repeating step 2.
    • The power button at the top of the device will be loose once the front part of the case is removed.
    Pergunte ao FixBot
    Comentar
  7. Disassembling IBM WorkPad c3 LCD, Battery: passo 7, imagem 1 %32
    • Remove the yellow tape that is covering the battery connector
    Pergunte ao FixBot
    Comentar
  8. Disassembling IBM WorkPad c3 LCD: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, carefully disconnect the battery cable from the port
    Pergunte ao FixBot
    Comentar
  9. Disassembling IBM WorkPad c3 LCD: passo 9, imagem 1 %32 Disassembling IBM WorkPad c3 LCD: passo 9, imagem 2 %32
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
    Pergunte ao FixBot
    Comentar
  10. Disassembling IBM WorkPad c3 LCD, LCD: passo 10, imagem 1 %32 Disassembling IBM WorkPad c3 LCD, LCD: passo 10, imagem 2 %32
    • Using the spudger lift the tabs holding the LCD/Digitizer combo cables to the WorkPad.
    Pergunte ao FixBot
    Comentar
  11. Disassembling IBM WorkPad c3 LCD: passo 11, imagem 1 %32 Disassembling IBM WorkPad c3 LCD: passo 11, imagem 2 %32
    • Using your thumb, press down gently on the back of the LCD.
    • The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 21-35, Regan Fall 2010 Membro de Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 2,310
