O que você precisa
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Remove the highlighted screw with a Phillips #1 screwdriver.
Pull the hard drive out.
Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
Slide the switch to the right. A black plastic tab will pop out.
Pull the plastic tab to expose the CD drive.
If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
There is a switch located just above and to the right of the drive.
Slide the switch to the right. A small, black tab will pop out.
Remove the following screws from the fan retention bracket:
Single 5.6 mm screw.
Three 16.1 mm screws.
Use a flathead to turn the screw 180 degrees.
Remove the CPU by lifting it upwards.
Locate the floppy drive bay.
Remove the four 5.6mm screws.
Remove the 16mm screw.
3 outras pessoas executaram este guia.
