Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
To take the floppy disk drive out, remove the battery first.
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
There is a switch located just above and to the right of the drive.
Slide the switch to the right. A small, black tab will pop out.
To reassemble, place the floppy disk drive back into its bay the way it was facing before
