Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
There is a switch located just above and to the right of the drive.
Slide the switch to the right. A small, black tab will pop out.
Pull the small black tab away from the computer to access the drive.
Gently pull the drive out from the laptop.
If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
