Ir para o conteúdo principal
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: passo 1, imagem 1 %32 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: passo 1, imagem 2 %32
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Pergunte ao FixBot
    Comentar
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: passo 2, imagem 1 %32 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: passo 2, imagem 2 %32
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    Pergunte ao FixBot
    Comentar
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: passo 3, imagem 1 %32 Disassembling IBM ThinkPad A30 Floppy Disk Drive: passo 3, imagem 2 %32
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
Membro desde: 10/06/10
162 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 4-44, Amido Fall 2010 Membro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membros
Autoria de 26 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 3,217
