Ir para o conteúdo principal
Disassembling Flip Video USB Port
O que você precisa
    1. Disassembling Flip Video USB Port, Outer Shell: passo 1, imagem 1 %32 Disassembling Flip Video USB Port, Outer Shell: passo 1, imagem 2 %32
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Flip Video USB Port: passo 2, imagem 1 %32
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Flip Video USB Port: passo 3, imagem 1 %32 Disassembling Flip Video USB Port: passo 3, imagem 2 %32
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Flip Video USB Port: passo 4, imagem 1 %32
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Pergunte ao FixBot
      Comentar
    5. Disassembling Flip Video USB Port: passo 5, imagem 1 %32
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Flip Video USB Port, Circuit Board: passo 6, imagem 1 %32
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Flip Video USB Port: passo 7, imagem 1 %32
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Flip Video USB Port: passo 8, imagem 1 %32
      • Disconnect the USB port cable from the back side of the circuit board.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Flip Video USB Port: passo 9, imagem 1 %32
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Pergunte ao FixBot
      Comentar
    1. Disassembling Flip Video USB Port, USB Port: passo 10, imagem 1 %32
      • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Flip Video USB Port: passo 11, imagem 1 %32
      • Lift wire out of the outer shell slot.
      • The wire mount should stay attached to the wire.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Flip Video USB Port: passo 12, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use tweezers to remove the spring that holds the port door shut.
      • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Flip Video USB Port: passo 13, imagem 1 %32
      • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Disassembling Flip Video USB Port: passo 14, imagem 1 %32
      • Remove the USB port cover.
      Pergunte ao FixBot
      Comentar
    6. Disassembling Flip Video USB Port: passo 15, imagem 1 %32
      • Remove the USB slider.
      Pergunte ao FixBot
      Comentar
    7. Disassembling Flip Video USB Port: passo 16, imagem 1 %32
      • Lift out the USB port slowly.
      • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth
Membro desde: 04/15/10
100 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 26-21, Regan Spring 2010 Membro de Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 4,508
