Ir para o conteúdo principal
Disassembling Ericsson CF 388 Circuit Board
O que você precisa
  1. Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: passo 1, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: passo 1, imagem 2 %32 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: passo 1, imagem 3 %32
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Ericsson CF 388 Circuit Board, Phone Casing: passo 2, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: passo 2, imagem 2 %32 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: passo 2, imagem 3 %32
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Ericsson CF 388 Circuit Board: passo 3, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board: passo 3, imagem 2 %32 Disassembling Ericsson CF 388 Circuit Board: passo 3, imagem 3 %32
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Ericsson CF 388 Circuit Board: passo 4, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board: passo 4, imagem 2 %32
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Ericsson CF 388 Circuit Board, Circuit Board: passo 5, imagem 1 %32
    • Locate the circuit board on the rear side of the front phone casing (right side of image).
    • Locate the mounting screws (indicated by red circles), which attach the board to the rear side of the front phone casing.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Ericsson CF 388 Circuit Board: passo 6, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board: passo 6, imagem 2 %32 Disassembling Ericsson CF 388 Circuit Board: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws. Hold the back part of the screw with the metal tweezers.
    Pergunte ao FixBot
    Comentar
  7. Disassembling Ericsson CF 388 Circuit Board: passo 7, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board: passo 7, imagem 2 %32
    • Completely remove the two center screw as shown.
    • Note: the hand not holding the screw driver is holding the back part of the screw and the panel in place.
    Pergunte ao FixBot
    Comentar
  8. Disassembling Ericsson CF 388 Circuit Board: passo 8, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board: passo 8, imagem 2 %32
    • Locate the final screw at the top of the phone near the antenna, as shown by the red circle.
    • Using the U-shaped screw driver, remove the top screw.
    Pergunte ao FixBot
    Comentar
  9. Disassembling Ericsson CF 388 Circuit Board: passo 9, imagem 1 %32 Disassembling Ericsson CF 388 Circuit Board: passo 9, imagem 2 %32
    • With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Clemson, Team 1-1, Benson Spring 2012 Membro de Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Membros
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 45
Ao todo: 1,663
