Ir para o conteúdo principal
Disassembling Epson PPC650 Replacing Flash
O que você precisa
    1. Disassembling Epson PPC650 Replacing Flash, Case: passo 1, imagem 1 %32 Disassembling Epson PPC650 Replacing Flash, Case: passo 1, imagem 2 %32 Disassembling Epson PPC650 Replacing Flash, Case: passo 1, imagem 3 %32
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Epson PPC650 Replacing Flash: passo 2, imagem 1 %32
      • Remove the two screws on the rounded side of the camera.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Epson PPC650 Replacing Flash: passo 3, imagem 1 %32 Disassembling Epson PPC650 Replacing Flash: passo 3, imagem 2 %32
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Epson PPC650 Replacing Flash: passo 4, imagem 1 %32
      • Remove the four screws from the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    5. Disassembling Epson PPC650 Replacing Flash: passo 5, imagem 1 %32 Disassembling Epson PPC650 Replacing Flash: passo 5, imagem 2 %32 Disassembling Epson PPC650 Replacing Flash: passo 5, imagem 3 %32
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      Pergunte ao FixBot
      Comentar
    1. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: passo 6, imagem 1 %32 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: passo 6, imagem 2 %32 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: passo 6, imagem 3 %32
      • Optional: Remove two black screws from top of camera on the flash side for more working space.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Epson PPC650 Replacing Flash: passo 7, imagem 1 %32
      • Remove clear rubber band holding flash in line with wiring.
      Pergunte ao FixBot
      Comentar
      • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
      Pergunte ao FixBot
      Comentar
      • Connect new flash by soldering copper ends to their respective ends to new flash element.
      Pergunte ao FixBot
      Comentar
Conclusão
Xan Danes
Membro desde: 02/14/13
134 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Buehl Spring 2013 Membro de Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 31
Ao todo: 660
