Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Shows how to remove/replace any part on a Dell Vostro V13 laptop.
O que você precisa
Remove the two (2) dummy cards from the laptop.
Using a Phillips head screwdriver, unscrew the six (6) screws from the bottom of the laptop.
Unscrew the two (2) screws from the back of the laptop, located at the extreme left and right of the back panel.
Slide bottom cover forward and lift upwards to remove. You may need to use a strong spudger to force a gap along the base edge from the ethernet port on the right, to the kensington port on the left.
11 outras pessoas executaram este guia.
2 comentários
is the CPU removable?
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
