Ir para o conteúdo principal
Disassembling Compaq Mini 110 Wireless Module
O que você precisa
  1. Disassembling Compaq Mini 110 Wireless Module, Battery: passo 1, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module, Battery: passo 1, imagem 2 %32
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Compaq Mini 110 Wireless Module: passo 2, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 2, imagem 2 %32 Disassembling Compaq Mini 110 Wireless Module: passo 2, imagem 3 %32
    • Push both tabs inward simultaneously and slide the battery out.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Compaq Mini 110 Wireless Module, RAM: passo 3, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module, RAM: passo 3, imagem 2 %32
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Compaq Mini 110 Wireless Module: passo 4, imagem 1 %32
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    Pergunte ao FixBot
    Comentar
  5. Disassembling Compaq Mini 110 Wireless Module, Keyboard: passo 5, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module, Keyboard: passo 5, imagem 2 %32
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    Pergunte ao FixBot
    Comentar
  6. Disassembling Compaq Mini 110 Wireless Module: passo 6, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 6, imagem 2 %32
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    Pergunte ao FixBot
    Comentar
  7. Disassembling Compaq Mini 110 Wireless Module: passo 7, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 7, imagem 2 %32
    • Unscrew the screw for the bottom case located in the RAM compartment.
    Pergunte ao FixBot
    Comentar
  8. Disassembling Compaq Mini 110 Wireless Module: passo 8, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 8, imagem 2 %32
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    Pergunte ao FixBot
    Comentar
  9. Disassembling Compaq Mini 110 Wireless Module, Hard Drive: passo 9, imagem 1 %32
    • Remove the three screws holding the panel in place.
    Pergunte ao FixBot
    Comentar
  10. Disassembling Compaq Mini 110 Wireless Module: passo 10, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 10, imagem 2 %32
    • Pull up on the tab to remove the hard drive.
    Pergunte ao FixBot
    Comentar
  11. Disassembling Compaq Mini 110 Wireless Module, Top Cover: passo 11, imagem 1 %32
    • Remove the eight screws that are from the plastic top cover.
    Pergunte ao FixBot
    Comentar
  12. Disassembling Compaq Mini 110 Wireless Module: passo 12, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 12, imagem 2 %32 Disassembling Compaq Mini 110 Wireless Module: passo 12, imagem 3 %32
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    Pergunte ao FixBot
    Comentar
  13. Disassembling Compaq Mini 110 Wireless Module: passo 13, imagem 1 %32 Disassembling Compaq Mini 110 Wireless Module: passo 13, imagem 2 %32
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    Pergunte ao FixBot
    Comentar
  14. Disassembling Compaq Mini 110 Wireless Module, Wireless Module: passo 14, imagem 1 %32
    • Remove the two screws holding the module in place.
    Pergunte ao FixBot
    Comentar
  15. Disassembling Compaq Mini 110 Wireless Module: passo 15, imagem 1 %32
    • Detach the two wires.
    Pergunte ao FixBot
    Comentar
  16. Disassembling Compaq Mini 110 Wireless Module: passo 16, imagem 1 %32
    • Just pull it out.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
alea
Membro desde: 10/06/10
1.429 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 22-2, Maness Fall 2010 Membro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 4,473
