Ir para o conteúdo principal
Disassembling Chef's Choice M115 Case
O que você precisa
    1. Disassembling Chef's Choice M115 Case, Case: passo 1, imagem 1 %32 Disassembling Chef's Choice M115 Case, Case: passo 1, imagem 2 %32
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Chef's Choice M115 Case: passo 2, imagem 1 %32
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Chef's Choice M115 Case: passo 3, imagem 1 %32
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Chef's Choice M115 Case: passo 4, imagem 1 %32
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
IUPUI, Team 3-3, Harley Fall 2015 Membro de IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Membros
Autoria de 14 guias
2Comentários do guia
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Responder Compartilhar
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 75
Ao todo: 2,479
