Introdução
This guide is used to disassemble the lens from the camera. This will be used to further clean the lens if you experience the E18 error.
O que você precisa
Remove the two screws that connect the LCD and backlight to the main body of the camera.
Ferramenta utilizada neste passo:Tweezers$4.99
Unplug the ribbon from the housing on the circuitry.
Take the new ribbon and insert it into the housing.
Tweezers or a tool with a sharp point can be used.
Detach the LCD and backlight.
Remove the larger screw.
Remove the two smaller sized screws.
Remove the small screw.
With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
Once you have removed the lens from the main chassis, gently brush off any dirt, sand, or dust that may have accumulated in the crevices. Using a compressed air canister or a brush can help remove all the dirt.
