Ir para o conteúdo principal
Disassembling Canon EOS 60D Removing Back Panel
O que você precisa
    1. Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: passo 1, imagem 1 %32 Disassembling Canon EOS 60D Removing Back Panel, Eye piece and Battery door: passo 1, imagem 2 %32
      • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
      • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Canon EOS 60D Removing Back Panel: passo 2, imagem 1 %32 Disassembling Canon EOS 60D Removing Back Panel: passo 2, imagem 2 %32
      • Open the battery door
      • Rotate the door so the one side of the hinge pops out (see photo #2)
      • Slide other pin out (it pops out the same, but this is easier)
      Pergunte ao FixBot
      Comentar
    1. Disassembling Canon EOS 60D Removing Back Panel, Rubber grips: passo 3, imagem 1 %32
      • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
      • Repeat for the other two grips
      • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
      • The small one on the back is a bit difficult to get started, but not really difficult to remove.
      • The one on the AV panel will be easier if you open up the AV port cover.
      • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
      • Optionally throw the balled up adhesive at people pretending its a booger :)
      Pergunte ao FixBot
      Comentar
    1. Disassembling Canon EOS 60D Removing Back Panel, Left-Side Port Cover: passo 4, imagem 1 %32
      • Remove 3 screws
      Pergunte ao FixBot
      Comentar
      • Remove the small Screw under the Flip cover too
      Pergunte ao FixBot
      Comentar
    2. Disassembling Canon EOS 60D Removing Back Panel: passo 6, imagem 1 %32
      • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
      • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
      • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
      Pergunte ao FixBot
      Comentar
    3. Disassembling Canon EOS 60D Removing Back Panel: passo 7, imagem 1 %32
      • Slide the rear part of the cover out.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Canon EOS 60D Removing Back Panel: passo 8, imagem 1 %32 Disassembling Canon EOS 60D Removing Back Panel: passo 8, imagem 2 %32
      • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
      • Slide down to remove without damaging the cover. (see photo with cover removed)
      • You can see how the cover, and side piece fit together in the second image.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Eric D
Membro desde: 11/13/12
1.377 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 48
Ao todo: 5,749
