Ir para o conteúdo principal
Disassembling Apple IIc Cover
O que você precisa
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: passo 1, imagem 1 %32 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: passo 1, imagem 2 %32
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Disassembling Apple IIc Cover: passo 2, imagem 1 %32 Disassembling Apple IIc Cover: passo 2, imagem 2 %32
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    Pergunte ao FixBot
    Comentar
  3. Disassembling Apple IIc Cover: passo 3, imagem 1 %32 Disassembling Apple IIc Cover: passo 3, imagem 2 %32
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    Pergunte ao FixBot
    Comentar
  4. Disassembling Apple IIc Cover: passo 4, imagem 1 %32 Disassembling Apple IIc Cover: passo 4, imagem 2 %32
    • Lift the handle straight up to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 21-23, Maness Fall 2011 Membro de Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Membros
Autoria de 20 guias
3Comentários do guia
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - Responder Compartilhar
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III - Responder Compartilhar
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 79
Ao todo: 11,436
