Ir para o conteúdo principal
Disassembling Antsle One D Server
O que você precisa
    1. Disassembling Antsle One D Server, Remove Front Plate: passo 1, imagem 1 %32 Disassembling Antsle One D Server, Remove Front Plate: passo 1, imagem 2 %32 Disassembling Antsle One D Server, Remove Front Plate: passo 1, imagem 3 %32
      • Remove the screws from the front panel.
      • There are also two screws in the front bottom of the plate that need to be removed.
      • When pulling the plate away from the body, be careful as a spring is keeping the silver button in place. The spring also easily slips off the button. Keep an eye out so you don't lose either of these items.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Antsle One D Server, Remove bottom plate: passo 2, imagem 1 %32 Disassembling Antsle One D Server, Remove bottom plate: passo 2, imagem 2 %32
      • To remove the bottom plate, remove the four-foot screws and the two screws from the rear plate, and the bottom will slide out.
      Pergunte ao FixBot
      Comentar
    3. Disassembling Antsle One D Server, Remove Back Plate: passo 3, imagem 1 %32
      • Remove the four screws from the rear plate
      • Unscrew the DC input connector
      • After, completing the previous step, and these six screws are removed, you can safely detach the rear plate.
      Pergunte ao FixBot
      Comentar
    4. Disassembling Antsle One D Server, Remove Front Panel PCB: passo 4, imagem 1 %32
      • Remove the two screws keeping the PCB mounted
      • Disconnect the power cable.
      Pergunte ao FixBot
      Comentar
    5. Disassembling Antsle One D Server, Remove the hard drive bay: passo 5, imagem 1 %32 Disassembling Antsle One D Server, Remove the hard drive bay: passo 5, imagem 2 %32
      • Disconnect the power and SATA cables from the hard drives.
      • Remove the four screws keeping the hard drives in place.
      Pergunte ao FixBot
      Comentar
    6. Disassembling Antsle One D Server, Remove the motherboard: passo 6, imagem 1 %32 Disassembling Antsle One D Server, Remove the motherboard: passo 6, imagem 2 %32
      • Remove the four internal screws keeping the CPU pressed against the heat sink (labeled orange).
      • Remove the four outer screws (labeled yellow).
      • Lift the motherboard away. The thermal paste may have good adhesion and additional gentle force may be needed to pry it away.
      Pergunte ao FixBot
      Comentar
      • Out of the box, the Antsle One D comes with 2 SATA hard drives. These can be disconnected from the SATA ports.
      • The front panel PCB is connected via a <look up> wire.
      • A power connector goes from the DC input to the motherboard.
      • A <look up> connector goes from the motherboard to the hard drive bay.
      Pergunte ao FixBot
      Comentar
    7. Disassembling Antsle One D Server, CPU & RAM: passo 8, imagem 1 %32 Disassembling Antsle One D Server, CPU & RAM: passo 8, imagem 2 %32
      • CPU - Intel C3558 SR388 2.20GHZ
      • RAM - DDR4 2666 RDIMM 1.2v CL19
      Pergunte ao FixBot
      Comentar
Conclusão
fausty
Membro desde: 06/16/24
725 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 376
