Ir para o conteúdo principal
Disassembling Ambient Weather AQIN Particulate Sensor
O que você precisa
    1. Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: passo 1, imagem 1 %32 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: passo 1, imagem 2 %32 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: passo 1, imagem 3 %32
      • Looking at the sensor from the bottom, you can see the two tabs/prongs that hold the outer case together.
      • There is a fine cable attaching the internal components of the PM sensor. Be careful not to disrupt/break it.
      • The internal housing will now be exposed. You can use the two tabs/prongs on this porting to remove that portion of the case.
      • Next, you can remove the 4 small screws holding the internal components to the outer shell.
      Pergunte ao FixBot
      Comentar
    2. Disassembling Ambient Weather AQIN Particulate Sensor: passo 2, imagem 1 %32 Disassembling Ambient Weather AQIN Particulate Sensor: passo 2, imagem 2 %32
      • Once the unit is disassembled, you can locate the internal motor of the unit.
      • Using compressed air, you may remove any debris that has become lodged on the intake shield of the motor.
      Pergunte ao FixBot
      Comentar
Conclusão
Tim Elafros
Membro desde: 01/23/24
493 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 206
