Ir para o conteúdo principal
Disassembling APEX AP-GS918 Screen
O que você precisa
    1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: passo 1, imagem 1 %32 Disassembling APEX AP-GS918 Screen, Power/Volume Button: passo 1, imagem 2 %32 Disassembling APEX AP-GS918 Screen, Power/Volume Button: passo 1, imagem 3 %32
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      Pergunte ao FixBot
      Comentar
    2. Disassembling APEX AP-GS918 Screen: passo 2, imagem 1 %32 Disassembling APEX AP-GS918 Screen: passo 2, imagem 2 %32 Disassembling APEX AP-GS918 Screen: passo 2, imagem 3 %32
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      Pergunte ao FixBot
      Comentar
    3. Disassembling APEX AP-GS918 Screen: passo 3, imagem 1 %32 Disassembling APEX AP-GS918 Screen: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      Pergunte ao FixBot
      Comentar
    1. Disassembling APEX AP-GS918 Screen, Battery: passo 4, imagem 1 %32 Disassembling APEX AP-GS918 Screen, Battery: passo 4, imagem 2 %32
      • Begin removing the black tape covering the motherboard inside the tablet.
      Pergunte ao FixBot
      Comentar
    2. Disassembling APEX AP-GS918 Screen: passo 5, imagem 1 %32
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      Pergunte ao FixBot
      Comentar
    3. Disassembling APEX AP-GS918 Screen: passo 6, imagem 1 %32 Disassembling APEX AP-GS918 Screen: passo 6, imagem 2 %32
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
      Pergunte ao FixBot
      Comentar
    1. Disassembling APEX AP-GS918 Screen, Screen: passo 7, imagem 1 %32 Disassembling APEX AP-GS918 Screen, Screen: passo 7, imagem 2 %32
      • The motherboard will need to be removed in order to access the screen.
      • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
      Pergunte ao FixBot
      Comentar
    2. Disassembling APEX AP-GS918 Screen: passo 8, imagem 1 %32 Disassembling APEX AP-GS918 Screen: passo 8, imagem 2 %32
      • To finish removing the motherboard you must release the two data cables holding the screen to it.
      • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
      • You can now remove the data cables from the slots and lift the motherboard out from the device.
      Pergunte ao FixBot
      Comentar
    3. Disassembling APEX AP-GS918 Screen: passo 9, imagem 1 %32 Disassembling APEX AP-GS918 Screen: passo 9, imagem 2 %32
      • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
      Pergunte ao FixBot
      Comentar
    4. Disassembling APEX AP-GS918 Screen: passo 10, imagem 1 %32
      • Pull the thin plastic screen casing apart and you can remove the damaged screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Megan Lozicki
Membro desde: 02/19/15
416 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-1, Leahy Winter 2015 Membro de USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Ao todo: 997
