Ir para o conteúdo principal
Direct-Drive Cleaner Head Brush Bar Replacement
O que você precisa
    1. Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: passo 1, imagem 1 %32 Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: passo 1, imagem 2 %32
      • First, make sure the device is unplugged and detached from the wand
      • Use a quarter to unlock the fastener marked by padlocks, turning it counter clockwise
      • Padlocks
      Pergunte ao FixBot
      Comentar
    2. Direct-Drive Cleaner Head Brush Bar Replacement: passo 2, imagem 1 %32
      • Slide the brush bar away from the cleaner head
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
UW Tacoma, Team S1-G5, Rose Fall 2017 Membro de UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Membros
Autoria de 45 guias
3Comentários do guia
While a clogged head was not the reason my Dyson V8 was stuttering, logic prompted me to check the big tube for an obstruction. My Dyson had a hairball as a result of picking up after my cat. Thank you!
John McCormick - Responder Compartilhar
My daughters Dyson V8 head is not powering the tube and rotating head. I have a Dyson V10 animal which I can attach to the V8 tube and rotating head and operates, so the problem is in the power head. I have cleaned the contacts and don’t know what else to do. Any suggestions?
Tom Murphy - Responder Compartilhar
I’ve cleaned it but it’s still not working. Any other suggestions?
Gem - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 110
Ao todo: 38,935
